disable ospf originate-default
Syntax Description
There are no keywords or variables for this command.
Default
Not applicable.
Usage Guidelines
Not applicable.
The following command disables generating a default external LSA:
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
